Alternator warning light question
Alternator at shop, was being re-built. Shop now testing unit post re-build, say can't get warning light to function. It is otherwise functioning. Any thoughts?
Jason |
New external VR installed?
Or is it a newer alternator with internal VR? If internal, they need to install a 5 watt 91 ohm resistor across the blue and red/black wires at the lamp socket on the gauge. As per the Technical Service bulletin about upgrading the alternator to internal VR type.. Like this one I made for my car. (Poor photo) http://forums.pelicanparts.com/uploa...1596236748.jpg |
FYI alt failed when bearings went, per diff thread. Thanks Jason |
Ok, possibly the remote VR was cooked with a big Voltage spike when Alternator failed.
| All times are GMT -8. The time now is 10:56 PM. |
