				Stainless Steel Muffler
			Tell me how to be sure that a muffler is Stainless steel. I am tempted to buy one used 911 muffler , owner says it is SS , but was not sure.It is looking like any muffler , some surface rust was visible.Not much.
				Any markings or something like that , to tell that it really is SS? Or any other method of testing it? e k i  |
			 Friend of Warren
			I believe most stainless steel is non magnetic. See if a magnet will stick to the muffler.
	Kurt V No more Porsches, but a revolving number of motorcycles.  |
 I asked SSI about that.. he said non-magnetic.. the magnetic ss will pit.. I buy marine ss nuts and bolts with a magnet.......Ron
	Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6  |
			Tried with a magnet , it DID stick!!! It has some numbers and a date 11/80 . Were stainless steel mufflers even available then?
	I donīt want to pay the premium of SS , and then finding out that it is a normal , rotten one.... e k i  |
			I have no first hand knowledge, but I have read on this board that some SS mufflers are stainless on the outside but use regular steel for the internal baffles.
	Neil '73 911S targa  |
			 Senior Member
 Using a magnet, the shell is indeed stainess, but you can see spot welds on the outside where the baffles are welded in. The magnet sticks tightly in those areas.
	'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M.  |
			 Senior Member
			Some stainless will attract a magnet, but not as strongly as the same size and thickness of normal steel.
			Doug is right about some of the stainless mufflers with their having normal steel being used for the internal baffles. These do rust out eventually and the muffler can be louder. Believe that SSI mufflers are going to be completely stainless while the Dansk can be a mix. Joe
	2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB  |
			 Guest
					Posts: n/a
			WHAT?
	Joeaksa Do SSI make mufflers? I thought they only made heat exchangers? INFO please
			I believe Monty mufflers are 100% stainless, inside out, baffles and all.
	George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS  |
			Stainless Steel Inc. (SSI) produces only the heat exchanger and some headers. The muffler is by others.
	Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic  |
			 Senior Member
 On Monty.....I almost bought one. John Walker likes 'em, they are well made. That was good enough for me. Until I met a SC/ Monty owner. He said the resonance around 2200-3000 rpm was driving him crazy! There were also some comments to that effect in the archives of this BBS. So it was Dansk for me, and I'm very happy with what I bought.
			I'm running the Dansk 2 in 1 out at the end of my SSI's.  The sound is nice but not "droney" like a ricer.
			 Guest
					Posts: n/a
			Harlan Chinn
	Thanks. It was also my impression that they didn't make mufflers, but Joeaksa's post got me thinking maybe they did. The thing is: I have a pair of SSI's on order with Wayne. I haven't ordered a muffler yet. I want 2 in 1 out (my own small survey tells me 2 in 2 out always produce resonance). I want to keep the flat six PORSCHE sound. (have heard systems that sounded like a fourcylinder BMW motorcycle or a US V8 engine)  |
			Cheaper grades of SS are magnetic.  OE mufflers are SS but are the cheaper grade and are magnetic.  They do rust but not a fast as if they where mild steel
	Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,  |
			BLOWN , thanks.
					Well , that would make sense.It was old , but not that bad.So I believe it must be somesort of SS , cheapergrade or something. MIKKEL , arent DANSK mufflers made in Denmark? Why not order your muffler directly from them?Just a thought.... eki  |
