John Tucker mentioned "new" clutch cable. If yours is original a new one will make a difference, correctly adjusted, of course.
When I bought my 85 911 11 years ago I was sure the 915 needed a rebuild!! It felt horrible! Until I learned to drive it. The only thing I replaced was the coupler . Then I learned to pause between shifts and sometimes double clutch going to first. A 915 will never shift like a Honda Civic SI or a Mustang GT. But it can shift very nice if you take your time. True story. Surprised no one has pointed this out.
Working on this project now. Remove all screws from the console and the passenger side foot rest (1 screw) then lift the Leather shifter boot and rubber donut up onto the shifter rod, pull and place the console on the passenger side floor board. Not the easiest job but be patient.
I also replace the motor and transmission mount first which made a huge difference. Bushings and coupler due to arrive today. Good luck. |
shifter upgrade progress
Thanks to all of you for your good advice! Using a combination of methods mentioned, we were able to get the console off of the shifter this evening which we were very happy about. Here's a pic:
http://forums.pelicanparts.com/uploa...1597803205.jpg We then removed the shifter. We struggled a little getting it out from under the carpet but it all worked out ok. So now the shifter is out. http://forums.pelicanparts.com/uploa...1597803388.jpg We took out the old ball cup shifter bushing and the shifter rod bushing. Here they are compared to the new parts that will be going on. They don't look all that bad, I think. It seems the shift coupler that we replaced this past weekend was in worse shape. Oh - the shifter rod bushing looks bad in this picture but that's more because we damaged it while trying to get it off of the bracket it was installed in. http://forums.pelicanparts.com/uploa...1597803525.jpg http://forums.pelicanparts.com/uploa...1597803553.jpg Hopefully this weekend we will get to install the new bushings. I'm also really excited to install the Karsten spring. Thanks for all of the good ideas - I'll post you guys once more progress is made. Thanks! |
Completed my project.
1. New Motor and Transmission mounts 2. New Shifter and Rod bushings 3. New Stomski Coupler RESULT.... It shifts like a NEW CAR. I am very happy with the results. Thanks Pelican for this forum and prompt shipping of components |
The ball cup bushing and the shifter rod bushing can be a PITA to install; I heat up some water in a coffee cup (not boiling; about a minute in my microwave is about right - YMMV) and drop the new bushings in and let them warm up. Makes them just a little bit more pliable and much easier to install. Dale |
Thanks, Dale! That's a good idea - because, yeah, you're right - those bushings do not want to go in easy! :)
shifter project update
Hi guys,
We finished up our shifter improvement project thanks to all of your help! We installed the new ball cup bushing and the shifter rod bushing. As Dale mentioned, those guys weren't easy to get on but eventually we succeeded. We also installed the Karsten spring to bring the shifter back to the 3rd/4th gear position when in neutral. Took the car out for a spin and I like it a lot. I'd say the thing that I like the most is the Karsten spring - it just feels better and tighter without the shifter freely swinging between 1/2 and 3/4 position when in neutral. Also helps me better feel where I am when shifting. Thanks a lot, everyone for all of your help! This is a nice improvement to our 911 and we couldn't have done it without you guys. |
I just installed the spring, and attempting to put back the shifter.
However, I forgot if the back of the shift rod collar slides above (against the shifter base) or below the tunnel?:( |
I'm no expert at all so I defer to everyone else but, if I remember correctly, I think the back of the bracket holding the shifter rod bushing went above the tunnel and directly into the shifter. If that's not right, others please feel free to chime in. Thanks! |
| All times are GMT -8. The time now is 07:12 AM. |
