-   -   Missing Chain Case stud and Cylinder check (http://forums.pelicanparts.com/porsche-911-technical-forum/1069205-missing-chain-case-stud-cylinder-check.html)
Nditiz1 08-03-2020 03:07 PM
So I noticed the rebuilt engine I have acquired is missing a chain case stud. Will this be an issue if the hole is stripped? Do I need to put this stud in to prevent oil from leaking?
Also, these cylinders have a marking on them 01 A 10. Can anyone determine what type of cyl these are Nikasil/Alusil
http://live.staticflickr.com/65535/5...50ed63d1_c.jpg
http://live.staticflickr.com/65535/5...05aa5287_c.jpg
Walt Fricke 08-03-2020 04:51 PM
For sure replace the missing stud. If the case threads are damaged (screw a short bolt and washer in and torque to spec. If you can get the torque, the threads are most likely good enough)you can use a Helicoil or other insert. Following directions drill the hole to spec, tap, and screw the insert in. Add the stud and good to go. Inserts develop full strength in this application.
Trackrash 08-03-2020 04:55 PM
By counting the fins on the cylinders, 11, they look to be Mahles.
Flat6pac 08-03-2020 05:11 PM
If it’s a 2.7. Mahle can also be alucil, Mahle went both ways.
Bruce
Nditiz1 08-03-2020 06:43 PM
Bruce - This is a 2.7 and you are right it could be either.
I will try to thread a stud in there.
