kstylianos's Avatar
Send a message via Yahoo to kstylianos
Whats This? - CIS Fuel Distrib. Valve Kit
While gathering CIS replacement items, I came across the following:
Fuel Dist Valve Kit K-Jet PshVlv
Is this a common ware item that should be considered for replacement while the CIS is out? Looks to come with shims, possibly for adjustability. May have my hands full with this R&R.
Thoughts?
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 04-16-2003, 02:51 PM
David's Avatar
I believe that this is the pressure regulator in the fuel distributor. I check my fuel pressure by removing the allen plug and screwing in a pressure gauge. If your fuel pressure is good, I would think just changing the o-ring would be enough. Just a few thoughts until someone more experienced chimes in.
Old 04-16-2003, 04:49 PM
The shims regulate the system pressure.
One shim = 0.4 - 0.5 Bar
Jeff
'72 911T gone
'85 TVR
Old 04-16-2003, 11:00 PM
kstylianos's Avatar
Thanks guys......
My CIS (knock on wood) has been trouble free since I bought the car. While its out of the car, thought I'd replace some common trouble items while I have the opportunity. These don't sound like common trouble or ware items to me. At least on mine, I have no leaks from the valves (so far) and no CIS issues that could be traced to system pressure. I'll just leave well enough alone w/ these.
Thanks again.....
Charlie Stylianos
1982 SC Targa
Old 04-17-2003, 07:35 AM
Heck, I’m only 5 not 71!
targa80's Avatar
When I rebuilt my engine I cleaned up the fuel distributor as much as I could and I pulled the pressure regulator and cleaned everthing with fuel injector cleaner. I did not have problems with the injection systems so I did not replace anything just made it look pretty.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 04-17-2003, 07:41 AM
Rob McKibbon's Avatar
I didn't think I had any trouble with my CIS system either? Until I put a gauge on it and found the regulator wasn't holding the pressure after shut off; which causes restart or cold start blues.
I replaced the fuel regulator completely. Anyone having starting troubles should test their fuel pressure. These CIS systems are major complicated, but I'm a learning?
Rob McKibbon, Shuswap Boy <><
To steal ideas from one person is plagiarism, to steal ideas from many is research.
Currently researching ideas for my '74 911 Cabriolet
Old 04-17-2003, 10:13 PM
