-   -   Msd (http://forums.pelicanparts.com/porsche-911-technical-forum/1069341-msd.html)
mike.bike 08-05-2020 01:51 AM
Msd
Hi, having problems with getting New MSD and Hot-spark ignition to work on my 911 1976, 2.7L that has contacts in distributor. Have installed after this drawing from MSD : https://www.hot-spark.com/Hot-Spark-MSD-6-series.jpg, but i only get spark on coil when i jump violet and green togeather, but not from distributor. I have a red wire from Distributor to red on MSD. A black from distributor to white on MSD ( but white has 12v when ignition is on) Green and violet from MSD i havenīt used. What am i doing wrong
Help my friends , cheers from mike
rwest 08-05-2020 02:38 AM
That diagram appears to show a special distributor from MSD; you should only have one wire from the Porsche distributor and that would go to white on the MSD and the red on the MSD should only go to a power source that is only on when the ignition is on and not to the distributor.
rwest 08-05-2020 02:40 AM
When you say contacts in your distributor, do you have a petronix installed or just the standard points?
MSD has tech support that could be helpful.
mike.bike 08-05-2020 02:59 AM
msd
Well there are two wire from distributor, that is because there is installed a HOT_SPARK electronic ignition set.A black and red wire
