-   -   Turn Signal Switch Connectors (http://forums.pelicanparts.com/porsche-911-technical-forum/1069501-turn-signal-switch-connectors.html)
ausgezeichnet 08-06-2020 05:26 PM
Replaced the turn signal switch in my 83Sc. Before I started I had no hi-beams but turn signals worked. After the install I now have hi-beams but no turn signals. I checked and double checked the 4 wires were installed in the correct positions on the headlight switch. However I have two white plastic connectors ( between the back wires in the picture), one male and one female with nothing to connect them to. The two between the black wires in the picture. The male wire is black with a white and green stripe. The female connector is a solid gray. Any idea of what to do with these connectors?
http://forums.pelicanparts.com/uploa...1596759992.jpg
proporsche 08-08-2020 07:10 AM
looks like nobody pitched in yet or here you go..you have to find the black and gren opposite wire same goes for the grey wire look at this picture from my 911..
Mind you if you are using new switch i has the white cover-connectors but the wiring has black cover
Ivan
http://forums.pelicanparts.com/uploa...1596895247.jpg
ausgezeichnet 08-08-2020 07:52 AM
Thank you! I saw the black connectors but I thought they were for something else because they did not have the same white connectors.
proporsche 08-08-2020 09:36 AM
u r very welcome;-)
Ivan
