Dept store Quartermaster
lendaddy's Avatar
Oil crossover pipe fitment problems
The new oil crossover pipe I am installing to fit my '85 930 heat exchangers is not ligning up correctly. Is it at all common for these large oil lines to need a little coaxing? The picture below shows where I believe the line should be and the red is where mine is currently at. The red arrow indicates where the bend is and the circled red arrow is where mine starts its bend. Do I have the wrong line or does mine just need some bending? Thanks
Cornpoppin' Pony Soldier
Old 04-18-2003, 05:29 AM
I get dizzy looking at your pic. I think your line looks right. I don't think it is supposed to go as high as the red lines
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 04-18-2003, 05:53 AM
lendaddy's Avatar
No, the red lines are where MINE is. This is a pic of another motor.
Old 04-18-2003, 05:56 AM
Then I would say yours is too high but I can't say for sure. What part of the line is the problem?
Dean
Old 04-18-2003, 06:01 AM
lendaddy's Avatar
If I leave it where it is the line that connects to it and goes to the Tstat will hit on the exhaust valve cover. I think I need to bend it down.
Old 04-18-2003, 06:03 AM
Maybe the line got bent in shipping. I would bend it down a little
Dean
Old 04-18-2003, 06:08 AM
Senior Member
Doug Zielke's Avatar
Listen here 'daddy....
Your project is doomed.
The motor may run, but will leak oil like crazy if you don't rebuild it rightside-up!
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 04-18-2003, 07:52 AM
lendaddy's Avatar
You're the devil. Curses I say, curses!
Old 04-18-2003, 07:57 AM
