How to clean rear hubs
Hello,
Im restoring my suspension. Here is what my hubs look like. Should I clean them? If so, whats the best method? Any insight would be appreciated.
thanks!
Old 08-08-2020, 01:14 PM
Glass bead.
206 637 4071
Old 08-08-2020, 01:23 PM
digitaldgp's Avatar
I agree with John, I did glass bead to mine and they looked brand new!
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
1967 911 Sold but Greatly Missed!!
Old 08-08-2020, 01:45 PM
kevingross's Avatar
Media blasting (such as glass bead) will certainly remove the corrosion. However, unless you follow that by plating or painting, the corrosion will return in short order. There's nothing wrong with your hubs, mechanically, as they appear. So it's really a choice.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 08-09-2020, 04:19 AM
4flyboy's Avatar
Glass bead, Por-15 in silver......
Mine look great years later
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 08-09-2020, 05:06 AM
Formerly known as Syzygy
Canada Kev's Avatar
How were they treated or finished when new?
Kevin
Old 08-09-2020, 07:30 AM
Harpo's Avatar
I sand blasted mine and had my coating supplier spray them with Magni.
Should be good for 1000 hrs of salt spray
Old 08-09-2020, 09:27 AM
Racer
winders's Avatar
Since you have them out, you might want to consider using magnaflux to check the integrity of the hubs.
Scott Winders
PCA GT-3R #3
Old 08-09-2020, 09:51 AM
thank you so much for all the suggestions guys! I think I'm going to go with glass bead.
This is off topic but, would any of you know where to buy caliper bolts/nuts? Im restoring my calipers and while i was disassembling them, I stripped a couple bolts/nuts because they were frozen. I posted in the classifieds but, no one replied.
Any help would be appreciated! Below is pic of what I'm looking for.
thanks!
Old 08-11-2020, 10:04 AM
Shaun @ Tru6's Avatar
Media blast and then either black zinc phosphate or Cerakote.
Zinc
Cerakote
Tru6 Restoration & Design
Old 08-11-2020, 10:16 AM
MBAtarga's Avatar
thanks!
Unfortunately, that hardware is NLA. There are several threads on them - and no one had found a direct replacement last I saw.
Trouble Finding Replacement Ribe Caliper Bolts
Mark
'83 SC Targa - since 5/5/2001
Old 08-11-2020, 10:42 AM
Calipers are so cheap these days you could buy one or two for the bolts you need and sell the others at a profit.
Old 08-11-2020, 11:22 AM
914-6Werkshop
Next time. Hold the bolt with a bit and remove the nut. Doesn’t hurt to hit the nut with map gas first for a minute
All used parts sold as is.
Old 08-11-2020, 12:24 PM
