Window/Door Frame Assembly- 1982 911 SC
I re-anodized window/door frame and cant put it back together. Cant find a detailed diagram for the window frame. Need help desperately. Pics show all disassembled parts laid out (#1) then lower bracket about to attach to frame (#2) then attaching to frame (#3). My concerns is that the triangular piece doesnt fit into the rail and just doesn't look right. It sit on top of rail rather in it. There is a gap between the bolt and the screw and sits metal to metal. Just doesn't seem right. Any help would be greatly appreciated.
Old 08-08-2020, 02:33 PM
Look at the other side?
Just kidding. I have an 83SC Cab. I will run out and take a look at the window frame.
Old 08-08-2020, 02:48 PM
Took the door card off. Tough area to get a look at. Hopefully someone else will chime in.
Good luck
Old 08-08-2020, 03:04 PM
