RSR Finish - Super simple 30 minute DIY
I decided to try my hand at creating an RSR finish on a set of Euromeisters that I have sitting in the garage. I have read just about every post on how to do this. I was not thrilled with the idea of masking the wheels...it just seemed like a LOT of work. But, I was really inspired by what I understand to be the original method that Porsche used - flooding or dipping the wheels to get the black part. Since I had a brand new set of wheels with good black paint, I decided to "reverse" the process by flooding the wheel with water to "mask" the area I did NOT want to paint.
Here is the step-by-step process that I used:
1. Use duct tape to seal off all the holes from the back side of the wheel. Be sure to use "waterproof" or "weatherproof" tape. I used the 3M version, which worked great.
2. SLOWLY pour water into the face of the wheel. I used a water bottle only filled about 1/2 way. You do not want to splash any water on the paddles where you want to paint.
3. Fill the water to the point where the black paint meets the unpainted rim. Make sure the rim is level. It will become obvious it if is not. Since my garage floor had a slight taper to it, I had to add a small shim to get it perfectly level. Again, the water line will tell you when it is perfectly level.
4. Spray paint in a light misting fashion. Do not get too close, or you will displace the water and end up with an uneven line. Obviously, the paint will adhere to the paddle and not the water. This is after the first coat.
5. Continue to lay on light coats until you have adequate coverage. I think I did 5 or 6 coats.
6. Let paint dry completely. Then use a toothpick to remove the paint film that formed on top of the water.
7. Use a the toothpick to rub gently along the paint line. It will free up any ragged pieces leaving a perfectly smooth line. The ragged pieces will simply float away.
Larry (Glenview, IL)
Past - '83 911 SC Cab - '95 993 Carrera 4 - '86 930 Turbo - '04 996 C4S - '88 930 Turbo
Present - '07 997 C4S - '87 Carrera - '85 Carrera backdate
Old 07-16-2017, 04:06 PM
8. And the finished product!
I'm really pleased with how it came out.
So, now for the mad scientist experiment that I went through to get to this point.
Initially, I did not want to paint the wheels for fear of making a mistake. So, I tried the same method described above using PlastiDip in Aluminum color. It worked OK, but the masking line was not as clean. I also found the color to be a bit too dark. Here is how that came out:
On a positive note, it is a great way to "trial" the RSR look without the full commitment of paint. Since it wasn't what I was looking for, I just peeled it all off and started over again. Just make sure to lay it on thick enough, otherwise, the areas that get coated too lightly are difficult to peel as it breaks into small pieces and is a real PITA to get it off.
Old 07-16-2017, 04:30 PM
MARISOL78sc's Avatar
Well done, love the reverse method! They look great.
Paul
2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951
1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold
Instagram: @rennsport98
Old 07-16-2017, 04:45 PM
After my PlastiDip experiment, I did a comparison study using other colors recommended in another thread. Rustoleum Metallic Matte Nickel #7277 vs. Krylon Dull Aluminum #1403 vs. PlastiDip Aluminum.
I filled 3 plastic plant saucers with water and tested each of the paints for color and cleanliness of line
I found that the Krylon paint "misted" better than the others. It also dried faster and separated from the side wall easier, leaving a clean line, and was "brighter" in color. ***Edit - Note: I just realized that the can of Krylon 1403 that I used is marked as "interior". In reviewing the older RSR finish threads, people who used this paint recommended using a clear coat over it.
In order from front to back, Krylon, Rustoleum and PlastiDip
Old 07-16-2017, 04:49 PM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
VERY cool. I did the reverse for my finish...same idea though. Love the notion of water as the mask!
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 07-16-2017, 05:02 PM
Super cool method thanks for sharing.
78 911 st backdate
87 944
00 996
Old 07-16-2017, 05:27 PM
Formerly known as Syzygy
Canada Kev's Avatar
Cool.
Hopefully your paint will stick well to the base black without scuffing prior to spraying.
Kevin
Old 07-16-2017, 06:04 PM
Great job, Larry. What a clever way to do it.
Thanks for sharing,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 07-16-2017, 06:06 PM
this is AMAZING! wow
Old 07-16-2017, 06:16 PM
Blown away, I'll be trying this method and posting pics here when completed.
Old 07-16-2017, 07:32 PM
Certified Porschephile
Great write up!
Old 07-16-2017, 07:41 PM
What the ?
glewis80SC's Avatar
Well done.
SCWDP 73
1980 SC
Harley Davidson Road King
9/11/01 FDNY/343 Never Forget!
Old 07-16-2017, 07:44 PM
Originally Posted by Canada Kev View Post
Cool.
Yup, good point! I should note that I wiped the whole wheel down with isopropyl alcohol. I also went over the black areas to be painted with a quick wipe of acetone. So, I'm pretty sure I got rid of any surface contaminants and the paint should stick ok. In any case, this was my test wheel. I still haven't done the other three, so I will evaluate this when I do the others.
My bigger concern - that I am just realizing now - is the Krylon can says "interior" on it. I will have to see if they make #1403 in an "exterior" version. It was one of the recommendations on another RSR finish thread. I was only focused on finding Krylon 1403.
So, I'm confident that the "water mask" process works well. I'm now less confident that Krylon 1403 is the correct paint to be using! ***Edit - I went back to review the older RSR threads that recommended using Krylon 1403. I noticed they also recommended using a clear coat (matte or satin) over it.
Old 07-16-2017, 07:45 PM
3 restos WIP = psycho
kenikh's Avatar
Very creative. Excellent work.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-16-2017, 08:56 PM
Canada Kev's Avatar
Yep, you could scuff and clear after, or if you find a different, acceptable paint, you might be able to spray the whole wheel with an adhesion promoter prior to the water mask. I think either would work.
Regardless, it's good to see someone thinking outside the box a little bit.
Kevin
Old 07-16-2017, 09:21 PM
Uncertifiable!!!
Uwon's Avatar
What a great concept. Well done!
Just my own opinion on fast vs slow drying paints. For durability, I prefer slow drying which I finish off with a couple of hours under a hot work lamp.......but then again that would negate your "30 minute DIY".
If you want to finish off with a shiny lip, put the rim on the rear hub and run engine in 2nd gear at idle. Use 800 wet sand to remove paint followed by 2000 then alum polish on rag. Non-positraction cars will need to brace the other rear wheel with a 1"X1" wood piece between the studs and against the floor.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 07-17-2017, 04:23 AM
Thanks, guys. I appreciate your feedback! I feel like my efforts have been validated. I certainly didn't get that from my wife yesterday....She just had that WTF look on her face every time she walked through the garage. Admittedly, it looked like I was conducting some sort of Consumer Reports project.
On a serious note, if anyone has suggestions for the best paint to use, I'd appreciate your input. It's funny, but when I googled the Krylon 1403, I found links to other car forums (like the Camaro guys) that were using it too. So, maybe just clear coating is the answer(?). In any case, I'm pretty confident that my experiment using the water masking works well and has real potential. If I can find the perfect paint (right color, finish, durability, etc.) this may be winning combination.
Old 07-17-2017, 05:26 AM
Spray paint is a waste of time and money, it has no catalyst, it will never harden.
Old 07-17-2017, 05:46 AM
kenikh's Avatar
You can buy catalyzed clear in a spray can at the auto paint supply. Done.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-17-2017, 06:37 AM
