3.4L with 20/21 cams done. Now will it pass CA emissions?
The first week of lockdown here in Michigan, I decided to pull my 3.2 from my '87 Carrera that was long overdue for valve guides. With 95k on the clock, the car smoked since I bought it 7 years prior, and burnt upwards of a quart every 300 miles or so. I put the repair off for years as I was building another car. As with most Porsche projects, it became a slippery slope with a number of "while it's out" upgrades. Specs as follows...
3.4L
10.3:1 CP pistons
ARP rod bolts (Rods balanced)
New steel head studs
Reconditioned rockers
Rebuilt heads (thanks Craig)
Web 20/21 cams
Bored throttle body to 66.5mm
Old FR Wilk 3.2 chip...always seemed fat before
Cat delete.
Dynomax muffler on stock HE
I've not got about 150 miles on the engine and it's pulling strong. Feels very eager and revs nicely to 6200 before it drops off. Will get it on the dyno soon to verify numbers and fuel. All said, I now need to move to Laguna Beach for work. Would like to know if people have passes emissions with the cams? I'd of course reinstall the cat.
Old 07-31-2020, 04:22 AM
famoroso's Avatar
My '88 with 20/21s passes CA smog.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 08-02-2020, 10:24 PM
Thanks Frank! You testing with stock chip too?
Old 08-03-2020, 06:20 AM
Targa_PB_78_SC
mike sampsel's Avatar
With the stock cat from Porsche, I presume?
I've 20/21's on my 3.2 SS with CIS, sounds like it has a chance with the right CAT. It's bypassed as I decide on the CAT.
BareRearedRookie
Old 08-03-2020, 07:20 AM
famoroso's Avatar
Yes, stock chip.
Yes, but came to find out that the stock cat was in this condition...
https://youtu.be/CNDkAZcb8AE
I'm shocked that the car passed with that cat.
I can dig up the results next week and post them up.
I have since added an open airbox lid, Dansk pre-muffler and Dansk 84mm sport muffler (same 20/21 cams) and had the car tuned by Steve Wong on the dyno...
The car runs STRONG and sounds GREAT.
Frank Amoroso
Old 08-04-2020, 03:42 AM
Should pass with O2 sensor and CAT
It it’s not original CAT, CA can be picky about the replacement
With all you’ve done it’s probably worth getting a SW chip, then have him adjust it based on dyno
Part throttle uses the O2 sensor but WOT uses a fixed mapping which Steve can adjust based on you dyno results
Old 08-05-2020, 04:01 PM
Cory M's Avatar
Single plug, 10.3:1, on CA 91 octane?
Old 08-05-2020, 04:23 PM
Yes. CC'd out to about 10.25:1. Have been running on 91 here in Michigan without issue or detection of knock. Then again, i'm not sitting on the rev limiter. Assume there are plenty of Euro 3.2's in the area. Not to mention that the static comp will be lower with cams.
Old 08-06-2020, 02:55 AM
Eva
911SauCy's Avatar
Does that dyno chart say 211 whp? (kinda fuzzy)
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 08-06-2020, 07:05 AM
famoroso's Avatar
Yes. 211.82 hp...
Also, sniffer test results. Passed pretty readily...
Frank Amoroso
Old 08-10-2020, 01:13 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Stock cat will clean a multitude of sins, you are good to go. Make sure you have the stock airbox and snorkel.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-10-2020, 10:34 PM
