-   -   Compression & Leak Down Results - Advice Needed (http://forums.pelicanparts.com/porsche-911-technical-forum/1070032-compression-leak-down-results-advice-needed.html)
Adam911Carrera 08-12-2020 01:38 PM
1986 Porsche 911 Carrera 3.2L
80,000 original miles
Compression: 160, 142, 150, 150, 165, 135
Leak Down: 30%, 60%, 30%, 35%, 30%, 80%
I am possibly purchasing this vehicle.
Original price was $35,000.
As a result of the tests above, dealer offered to sell for $25,000.
It appears that a rebuild is in my future, but the car actually runs well and no smoke.
The motor did have some normal seepage but no active leaking.
Pictures attached.
Question: Should I purchase this vehicle? What do the test results say? Risk? Future cost assessments? What would you do? How would you negotiate this?
Any advice would be greatly appreciated as I am a first time Porsche buyer.
THANK YOU!!!
http://forums.pelicanparts.com/uploa...1597264503.jpg
proporsche 08-12-2020 01:46 PM
hmm ??? is this a wide body? Looks like a Turbo kit..can you provide more pictures?The rear rims are aftermarket 9th ..front original Fuchs 7th..really more pics will help to help you.Otherwise the price is nice...also check the engine numbers..do you know where to look?..herehttp://forums.pelicanparts.com/uploa...1597265086.jpg
the black arrow and where finger is pointing...is it the original color ...?
Ivan
ps..i wonder about the clutch ,there is a return spring missing on the bottom..that is all i can tell you from what i see.....
Adam911Carrera 08-12-2020 02:00 PM
Wide body kit. Paint is not original (they said they would repaint Guards Red for $5K). I don't have the engine number (what will that help me with? to see if matches?). H4 lights. They are going to repair the seats. Cab top is new. Shifts a little rough into 2nd gear. Does not downshift to 1st unless completely stopped. 915 transmission. More pics below. Let me know if you have any advise, info, or suggestions. THANK YOU!!!
http://forums.pelicanparts.com/uploa...1597265789.jpg
freeform911 08-12-2020 02:07 PM
Wow..that car looks pretty clean for $25k
safe 08-12-2020 02:13 PM
The leak down numbers are very poor, but $25k is cheap!
boyt911sc 08-12-2020 02:16 PM
Yellow cabriolet.........
Pictures attached.
THANK YOU!!!
Adam,
If that yellow car has a legitimate registration and title, I will buy it even if the motor is not running. Let’s look it this way:
  • The value of the chassis less transmission and motor at $15K.
  • The value of the transmission at $2K (core value).
  • Assume the motor needs a rebuild and a core at $8K.
If you pay $25K for this car even if it is not running, you will make a profit for this purchase. Someone will take it right away if you don’t decide fast enough. My two-cents.
Tony
Travis Neff 08-12-2020 02:18 PM
Check the VIN, was it a targa converted to a cab? is it a factory widebody car, or was it done later - and why. Was it in a collision and that's when it was decided to change things up?
A rebuild is going to be 10-20 grand if your paying someone to do the work.
Adam911Carrera 08-12-2020 02:32 PM
Carfax is clean... no collisions and says its a convertible (cabriolet).
brshap 08-12-2020 02:38 PM
Have you had an independent PPI?
If everything else checks out even if you factor in a rebuild sounds like you're still money ahead.
Adam911Carrera 08-12-2020 02:53 PM
No PPI but the dealer put her on the rack for me and I checked for rust and leaks. I did not see anything of concern. Noticed Bilstein shocks were added.
proporsche 08-12-2020 03:21 PM
so, you are saying it is 1986 Cabriolet,Turbo body???very strange..i`d say
Ivan
Crude Rudy 08-12-2020 03:23 PM
I would sure as hell get an independent PPI done before I bought a car I know needs at least a top end build - the while your in there cost could add up quick if it needs other work
Adam911Carrera 08-12-2020 03:34 PM
Ivan
The wide body was a kit. Not a factory turbo-look or turbo body...
911 SLANT 08-12-2020 03:36 PM
Where is car located?
proporsche 08-12-2020 03:38 PM
i know that;-)more strange to me;-)80 k on the vehicle;-)
Adam911Carrera 08-12-2020 03:56 PM
Is it a good thing or a bad thing in your opinion? Im a newbie Porsche buyer...
proporsche 08-12-2020 04:04 PM
Adam...to the outsider the 911 looks nice..but please do some checking into it.
1.service records
2.who and why was the conversion to 930 done.
3.really check the engine numbers
4.is there a carfax available?
5.before you put any $$$ down have it checked by Porsche specialist,if you can find one nearby?
6.check it and report here we will help you out..
Ivan
Adam911Carrera 08-12-2020 04:13 PM
1.service records
Ivan
Can you advise me the importance of checking the engine numbers? Is the purpose to determine whether it is the original engine? How do I confirm that once I obtain the numbers off the engine? How does this affect value or utility?
Thanks a million.
boyt911sc 08-12-2020 04:52 PM
Wide body conversion........
Adam,
Was the wide body conversion done with steel flares or Fiberglas? Steel is more desirable and add more value to the car compared to Fiberglas. Keep us posted.
Tony
autoenthus 08-12-2020 04:59 PM
Adam - In general, you want to know if the motor is original because a "numbers matching" car is generally more valuable than a car with a replacement motor. In this case, it appears that the car has already been modified, so the value will not be the same as an all original car.
Regarding your original question - asking for advice - there may be some potential here, IF the car does not have any skeletons. The motor is only one piece of the puzzle. For a first time buyer, this one seems to present a number of questions/concerns, any one of which could make this a nasty transaction for you.
Answering a few questions might help you decide - Are you the kind of person with a high tolerance for risk? Why are you attracted to this car?...because the price dropped?
ClickClickBoom 08-12-2020 05:22 PM
If you like the car and it has no unseen damage repairs, buy it. Those compression numbers are fine for a car that has been sitting on a dealer lot. Differential Compression tests are more of a trend monitoring tool. One time test is pretty close to useless. It has compression, buy it.
Adam911Carrera 08-12-2020 05:33 PM
Thanks for all the feedback and questions.
I am meeting with the dealer tomorrow and I have an email in to him about the engine numbers and some of the other items mentioned here.
I'm leaning towards making the purchase.
I will keep you all posted.
Anything else I should consider or look at when I'm there tomorrow?
911 SLANT 08-12-2020 06:46 PM
Make sure you know what your in for. The dealer your buying from deals with Exotic sports cars. They know what car is worth. I would be skeptical on why they are selling so cheap. Check the the numbers on body and motor and trans. Write them down and post on Pelican. Someone can check to see its authentication. Hopefully turbo flares are factory when car was ordered. If not and they are butt welded then might have a issue on value. I would definitely have a Reputable Porsche mechanic do a full run down before purchasing.
Don't let the good looks fool you. Good luck!
ClickClickBoom 08-12-2020 08:53 PM
There is 25k in parts there, not a lot of risk...
safe 08-12-2020 11:58 PM
A factory turbo look (WTL) cabriolet would be VERY valuable.... There is collectors for these cars.
I don't think the VIN will tell a difference between a Targa or a Cabriolet.
safe 08-13-2020 12:08 AM
A WTL (option M491) would also have the turbos brakes. From 86 the fenders are a one piece, not a welded flair. This is things to look for.
But for 25k, just buy it... if your not happy I'll take it of you hands.
Crude Rudy 08-13-2020 10:54 AM
If you are having trouble shifting 1-2 or into 1st now you are saying its needs a trani rebuild too and while you are in there might as well do the clutch and axles too
Top end and trany/clutch at a shop you probably looking at $15-20K in work if not more at $150/hr labor rate
I would pass and find a car that all ready is sorted out for $35K if it was me
nene 08-13-2020 11:18 AM
Great info, but scary for the 1st time Porsche buyer.
Serge
Locker537 08-13-2020 11:28 AM
I agree with you and Tony, but I want to play Devil's advocate.
Yes, there is 25K in parts.
However, if Adam wants to turn it into a reliable driver, the cost of rebuilding the engine, transaxle, all the little things, can quickly exceed the purchase price.
If that car was in pristine condition, what would it be worth?
Granted, these are often passion projects and the money is not the first concern, but I agree with knowing what you are getting into.
aston@ultrasw.c 08-13-2020 12:15 PM
IMHO the compression numbers are not great, especially for 80k miles - 280k miles maybe.
The leak down numbers are flawed. In theory the best you can get is 0% i.e. zero pressure leaking from the combustion chamber.
On an 80K motor *warmed up* I would expect 2% to 6% of leakage.
So 30% and 80% - is that 30% and 80% leaking :eek:
or 30% and 80% or zero leaking :eek::eek:
Most owners would want an engine and trans rebuild in the near future.
I would go for the $35k truly solid example.
This is tough time to sell a car, if you really want it, try for another $5k off.
Glenfield 08-13-2020 12:27 PM
Adam, should definitely call the dealer and get answers before you go out there. That way this forum can help you value the potential of the car. You’ll be more knowledgeable on the car too and dealer might leave the skullduggery for someone else. Definitely get:
1. engine and transmission number and VIN number. All on the car and shop can get those in 2 minutes. With those, you can work out (a) if engine matches the production period indicated by the VIN and (b) if transmission is correct for the model too
2. VIN is good for an accidents report if post 1980
3. See if there’s an owners book or options list with the M491 option. That’s unlikely but would be gravy
There’s a world (that’s not too difficult to imagine) where you spend 25k on the car and then another 25k making it right. That’s a good trade if the cars worth 60k+. Not so much if it’s a Frankenstein as that will take some $$ before you can pronounce “it’s alive!”.
Ferdinand Magazine is a Porsche blog that has a good article on inspecting a car in person. Be a good one to read.
ClickClickBoom 08-13-2020 12:45 PM
Differential Compression tests are a trend monitoring tool, and are subject to the skill of the mechanic. It is not a difficult test, but unless you rock the pistons on a operating temp engine, its a waste of time and energy. I have watched skilled, experienced A&P mechanics state an engine is un-airworthy, yet when I performed the test according to the Continental and Lycoming service bulletins, checks out fine. I have done more than a thousand of these over 30 years as an A&P.
Adam911Carrera 08-13-2020 08:04 PM
UPDATE: I bought the car today for $25K. Looks like we'll be chatting a lot in the coming weeks. Nice meeting everyone... I look forward to our future conversations!
Trackrash 08-13-2020 08:27 PM
OK. Now drive the car. Report back.
I am having a hard time believeing the leakdown numbers. IMO, if it is not smoking after warmed up and not burning a ton of oil, and if it doesn't have any broken head studs, you are good to go.
BTW, did the "mechanic" that did the leakdown check for broken head studs? Did he tell you where the air was leaking out?
Spend some time learning about the car and it's unique mechanics before considering any major repairs.
Here is a story similar to yours. There is a lesson to be learned here. http://forums.pelicanparts.com/porsche-911-technical-forum/1058931-buy-911sc-they-said-will-fun-they-said-6.html
nomore 08-13-2020 09:28 PM
CNC motors, Upland CA. They have bigger fish on the fire than this Porsche. From the pictures on their website it looks like 25k is the mornng coffee run. They just didn't want to deal with the car that could have "problems". Good luck with it; and actually drive it before "fixing" it.
Locker537 08-14-2020 06:35 AM
Congrats on the purchase!
safe 08-14-2020 06:56 AM
Congratulations! Without seeing the car in real life it sounds like a good deal.
I would check valve lash, try some seafoam in the cylinders, have a good "italian tuneup" and recheck the leakdown, it might be stuck rings or something. Next leak down try to pinpoint where its leaking, rings or valves.
ClickClickBoom 08-14-2020 10:39 AM
Check the date:
http://forums.pelicanparts.com/porsche-911-technical-forum/645161-porsche-heal-thy-self.html
