Slight Change in Oil Pressure - Concern???
So over the past 4-6 weeks, I've noticed that both my idle and druck gauges are running a bit lower.
May-ish and earlier...idle pressure was very near the top-max line and druck was 4.5-ish at 3K-4K. Now idle is closer to dead-middle and druck is 3.5-ish at 3K-4K. -No oil change. -No change in oil level (checked several times, engine warm and running). -Car running exactly as it always has, which is silky smooth. -No other issues of any kind. -It is warmer outside (duh), and the car is running warmer than, say, Jan-April. Anything to be concerned about? I'll be changing the oil in the next month (annual change), but what's in there is damn clean.
Current: 1984 911 Targa Whale Tail "Gemma" 2014 Boxster S (wife) "Sir Jenson" (She named it...not me) Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4 |
Under the radar
What oil are you running? What have the ambient temperatures been lately?
Warmer the engine gets the oil will thin and your pressures will be lower. Jan-April is what around 45 degrees in WA? I think you are fine..
72 914-6 GT Conversion 2.7 82 911 SC Coupe 78 SC Targa Hotrod |
The PO had Mobile 1 Synthetic 15-50 used for an oil change last May. The one and only John Walker did the work at his shop.
Car has 1300 miles since then. Temps have been in 80's this summer.
"druck is 3.5-ish at 3K-4K." That is in spec, 1 bar for every 1k in RPM up to 3500rpm
I wouldn't run synthetic in a aircooled motor.
yup, i would never put it in an air cooled engine.. Ivan let`s hope this does not go to oil discussions;-)
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks Jason
'79 911SC Targa |
Very normal for warmer weather. I’m a big fan of Mobile 1 15W-50.
72 Carrera RS replica, Spec 911 racer |
That said...oil change coming next month...hummm...opinions??? JUST KIDDING!
Yes. Sorry...the OEL gauge next to the fuel level.
