Setting timing at 6000rpm
Hey, just curios how many 911 owners that work on their own cars actually set their timing at 6000rpm? I find it a terrifying experience and haven't had the courage to get the revs up there yet, my timing is set at TDC at idle. I have a 1970 911T, runs really well so I wonder how much better it would be setting the timing to spec?
Ive just got mine going after a rebuild. I've set mine at idle and then ear. Ive advanced it so much and it makes a lot of difference. It does not ping. Will do for the run in. I would definalty check it at six thousand. Won't hurt it a bit.
Lyndon |
Full advance happens well below 6000 rpm, probably closer to 4000 rpm. So no need to rev all the way to 6k. 4k is bad enough with your face next to the fan belt!
It's just to check full advance, not to set the timing.
Sherwood |
Yes full advance not timing. If I adjust the distributor for full advance (35btdc) will this not affect the idle setting? If it does is this telling me there is wear somewhere or is it aback and forth procedure getting the idle and advance as close as you can?
You can't hurt the motor by revving to 6000 rpm. The timing at 6K rpm is to check the maximum advance, which in your case is 35 * BTDC.
I am assuming you have the rev limiting rotor installed.... |
My late father who had a masters in mechanical engineering and worked on experimental engines at GM before going into aerospace used to say that it was much harder on an engine to take it to high revs unloaded than it was under load, say on a dyno. I don't know the technical answer why, but I always keep that in mind. That said, 911 engines have a very stout bottom end and I have witnessed them taken to screaming revs with zero load.
After checking total ign. timing at 4500 rpm +, check again at idle speed (~800 rpm). You now have the timing specs for idle and distributor ignition advance. |
If you look at the ignition curve for the 2.4 and 2.7 engines, total advance does not happen till about 6000 rpm. I would check your advance at various rpm to make sure the distributor weights are moving smoothly. If not it may be time to do a little distributor maintenance.
http://forums.pelicanparts.com/uploa...1597835073.jpg |
Or am I wrong on this one? |
just dont keep it there long. Hard part is seeing the tack and timing light. Rev it and confirm it wont over advance. It can take it. its a Porsche. Neighbors love it also;).
Interesting the chart does not show correct timing at idle. Should be 5 degrees ATDC with retard hose connected. 73 911 E |
David Inc. is correct in his assessment.
cmcfaul, if you read the text at the top of the picture, timing is set with vacuum line disconnected. At idle with vacuum line attached yes, it should retard the ignition. If not the vacuum pod could be malfunctioning, or the distributor plate could be sticking, in which case it would be a good idea to have it serviced. |
A 2.2 engine only advances about 1 or 2 degrees past 4k rpm. Most of the advance is in the early revs. |
I live in a town which is really just a whole lot of hills stuck together. So I get to do a lot of 6,000rpm under full load Italian tune ups. Plus we have a white trash town called Wainuiomata nearby with a very big steep both sides. So kind of handy. |
To check my total timing at high RPM, I don’t linger at high RPM, I line up my timing light on the timing marks, reach over with the other hand at briefly open the throttle and then close the throttle. The engine will just rev up then immediately go back to idle. If you are watching the timing marks, you will see the timing advance and then stop advancing - this is your total advance. If there are any adjustments that need to be made, I rotate the distributor at idle and then check total again with a quick rev. I don’t worry too much about what RPM the total occurs at. Quote:
http://forums.pelicanparts.com/uploa...1598012088.jpg |
| All times are GMT -8. The time now is 07:27 AM. |
