Front 964 caliper mod
Can some one please measure the height of a caliper that has been modified for use on a S/C type strut. I need to know how much of the ears to machine off.
I borrowed this photo from pu911 who just sold the set up that I'm trying to create http://forums.pelicanparts.com/uploa...1597619031.jpg |
Beggars can't be choosy but in a perfect world some one has a pair that were just "professionally" machined and they have access to a surface plate and a height gauge. Could I also get the drill and tap depth please?
http://forums.pelicanparts.com/uploa...1597624497.jpg http://forums.pelicanparts.com/uploa...1597624497.jpg |
So I simply remove enough of the ears to create a flat spot big enough for the adapter bracket to sit on?
Thanks David |
Is this the correct part number 930 351 047 00? This looks like a floating rotor design. I don't believe that I need or want floating rotors
You can use it or a same size non floating rotor, w/ either you need a flat hat, if you want floating you need all the other parts for the '78 rotor note that the 930s went to a 1 piece design w/ integral hat in '80, this rotor cannot be used w/o 930 fenders and hubs floating http://forums.pelicanparts.com/uploa...1597780443.jpg http://forums.pelicanparts.com/uploa...1597780443.jpg non http://forums.pelicanparts.com/uploa...1597780443.jpg |
| All times are GMT -8. The time now is 02:41 AM. |
