Cylinder scoring
Went to the track and ended up with a coat of oil over the engine. I took it to a reputable race shop where they performed some testing. "Oil leaking after track event. Oil pooling under intake . Perform leak down and compression tests. 15% leakage on cylinder #2, scoring on bank one cylinder walls."
So my question is what can I do to fix this? I do not want to scrap the engine as I can daily drive it with out blowing oil everywhere. Can I do new pistons on that bank of cylinders with new or used cylinder (heads?/Jugs? I don't know the proper term)? I would love some input. Thanks for your help. |
Be careful PSManring.
I had a mechanic perform a leak down and compression test which returned similar results on cylinder #5. He borescoped the cylinder and diagnosed cylinder scoring. Tore engine down and cylinder #5 was perfect. Compression/leakdowns return false negatives and borescopes invite user error. Even at the most respected shops. You have different symptoms and do appear to be more consistent and uniform. Also unlikely to have any carbon buildup skewing numbers. Just my 2 million cents though. |
Caveman Hammer Mechanic
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Perhaps you just overfilled with oil and extra heat of track event caused oil to expand, leading to spillage. I never fill higher than halfway between marks on dipstick, checked with engine warm and idling.
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
What engine are we talking about 3.0, 3.2, 2.7 ?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
^^^^^ This, what engine is this? Is it stock or modified in any way??
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Under the radar
Let me see if I got this correct. The engine blew out some oil, and the mechanic did a compression, leakdown, and borescope? Not sure how those tests would find the source of the oil leak.
Did he check the oil level or the tank vent setup? Leak down means little with out knowing where the air is leaking. Scoring on bank one? What does that even mean? I could be wrong, but it sounds to me like this mechanic is looking for work.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 08-13-2020 at 08:40 PM.. |
Volume of oil at different temps is the same until it becomes gaseous.
Rescuer of old cars
Not so sure about that. Both of my Porsches ('84 3.2 and '72 2.4) show low on both tank gauge and dipstick until fully up to temp. Easily a full quart difference from cold to full warm. So there's some expansion going on in there.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Plug in whatever numbers you prefer: https://my.hostmysite.com/ssl/30/thermotab.net/infoPages/Table_limits.html
It's a 914 ...
Excessive blowby can result in excessive oil mist coming out the breather and result in coating the engine with oil, but there are many other possible causes. I'd want to give the engine a good cleaning and then reproduce the leak to trace the source before making any decisions how to proceed.
Under the radar
I have had a motor that had broken piston rings in one cylinder, so basically no compression. The symptom was LOTS of smoke coming out of the breather. Enough that I could see it in my mirrors while driving at night. Still there was not any noticeable liquid oil blowing out. (this was not a 911 btw) Is that what the mechanic was thinking was wrong with your motor? Maybe you could share the numbers from the compression and leakdown tests?
It's a 914 ...
Sometimes excessive blowby can result in the extra oil overwhelming whatever it is that catches is. For most stock 911s, I believe this would be the airbox, which can start to fill up and/or leak. And then the mess ensues.
Or it could be as simple as a leaky breather hose. Tracing the source of the leak will reveal a lot. |
https://www.engineeringtoolbox.com/temperature-density-petroleum-lubricating-oil-lubricant-volume-correction-ASTM-D1250-d_1943.html
1984 Carrera 3.2 Targa |
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 08-14-2020 at 04:20 PM.. |
So if you take the volume correction factor of 1.0 at nominally room temp your 10 litres=10litres at startup say. With the volume correction factor of 1.075 lets say nominal operating temperature you would have 10L*1.075=10.75L , and increase of 7.5% volume. A not insignificant difference. Can you explain how you arrived at your numbers? I don't follow.
I will get a second opinion before investing a TON of cash! I have not been able to reproduce the symptoms that I got at the track.
Thanks |
