Cold cranking oil pressure ???
I was wondering what cranking over motor oil pressure should be. I have a fresh rebuilt 2.8 that I want make sure that pressure is correct before actually starting up. I disconnected coil wire and cranked it over. I can almost reach 1 bar on gauge. Its about 3/4. I know that 1 bar equals 14.5 psi. So I figure I'm getting around 9psi. Is that good enough oil pressure to start motor?
Old 08-25-2020, 06:57 PM
Yes it is , the motor is spinning at about 225 rpm. 9 lbs is just fine .
When it starts idle it at 1500-2000 rpm . watch the OP 10 lbs per 1000 rpm,
when at operating temp, is the guide line .
I'll bet you will have more than that when it is coming up to temp.
If the OP won't go over 25 psi shut it down , you might have a seal leak.
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 08-25-2020, 07:19 PM
Ok, cool. I'll give it a try tomorrow
Old 08-26-2020, 11:06 AM
