franklinstower's Avatar
Quarter window outside seal
I just noticed the drivers side of the "vent" window doesn't have the seal between the door and the quarter window frame that is present on the passenger side...I think this is the part number: 901-531-933-20?
Missing seal between door trim and window frame:
Not Missing:
does this require pulling the window frame to replace? I would assume it just slides into a channel, correct?
Thanks for any tips.
'78sc coupe / 89 Westy - EJ25 frankenmotor
Old 08-24-2020, 01:53 PM
The seal is attached to the flat trim on the top edge of the door , which is held down by spring clips.
I would think you can pry it off with plastic trim tools.
As you say the new seal will slide into a channel.
Old 08-24-2020, 02:55 PM
Cool, thanks.
I easily removed the trim on the good side. That little trim piece is just held in place by a few dabs of weather strip adhesive.
Thanks for the tip.
Paul
Old 08-24-2020, 05:32 PM
