Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Need a photo of OEM rear banana arm mounting point.
Hey all. I’m reverse engineering this race chassis, and I’d love a picture of the OEM mounting point if you have a chassis handy. Thanks!
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 08-22-2020, 01:04 PM
Rodney Nelson's Avatar
HI Michael,
I'm sure someone will post a better picture for you but I just took this one today of my '72, if you zoom in on the pic it may help. There is a non-factory bolt welded onto one of the mounts.
Looking forward to your next video... what is taking you so long
Thanks,
Rodney
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold
Old 08-22-2020, 08:43 PM
Rennch on YouTube
rennch's Avatar
Thanks. This thing is kicking my ass for the last three days. I’ll explain more in the video.
Michael O'Neal -
Old 08-22-2020, 10:16 PM
Mahler9th's Avatar
What specifically are you trying to do? What year car? Looks like the inner pickup points have been moved up about two inches with those camber boxes. It also looks like the other pickup points have NOT been moved up, yet there are some custom spring plates.
Are you looking for measurements or just pictures? There are plenty of pix of that area in these Forums from various 911s.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 08-23-2020, 12:39 PM
Rennch on YouTube
rennch's Avatar
Ideally I'm trying to cut these camber boxes out and give me more room to operate in there.
I've searched a lot...but there's nothing that specifically points me to this inner pickup point.
Michael O'Neal -
Old 08-23-2020, 02:06 PM
GG Allin's Avatar
Best ones I've got.
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 08-23-2020, 02:59 PM
It looks like your boxes have been built onto the stock mounting points .
If you wanna drive down to Laguna hills you can take a look at mine , take measurements etc .
It’s stripped down and on a chassis dolly allready
I’m just off the 5 at la Paz (2 past eltoro )
Old 08-23-2020, 03:11 PM
Evan Fullerton's Avatar
You are planning on running 15" or 16" wheels with your Subi swap with a 24-25" tire?
You are going to need all the space cut out in the center to fit the 996 box, looks like your chassis is setup for a 993 6-speed right now?
You aren't going to ever be able to run torsion bars with a 6-speed unless you really mod things for '87-'89 g50 style torsion bars.
Why not just set the ride height and alignment with the spring plates you are going to run, be they stock pivot point or bolt on "935" style raised spring plate pivot ones, and then you will know where in that adjustment range you need to be. For your use if my assumptions above are correct, that inner pickup point adjuster just lets you get the camber adjustment into the correct range at the ride height setting and outer pickup point location. Bolt on "935" style spring plates only raise the outer pivot ~25mm so even if you do that, you can cut off a good 2.5in or so off the top of the adjuster boxes as you will never need that range of adjustment.
Just be sure once you are done cutting things you don't need off that you add sufficient structure back. Any time the torque tube is cut all the way through like that, you loose a lot of stability in the pickup point mount and without knowing where they attach, it's hard to say but the current tube reinforcement that is done doesn't look to have the greatest load support path.
Old 08-23-2020, 03:13 PM
Hi Michael,
I'm not sure I would get rid of those. Do a lot of research first. Ahhh Garage Time, Tom, did a video on creating what you have for his 911. It helps with improving suspension. I'm not even a beginner on this topic. If it is not in the way of your transmission/engine I would see if you can keep it?
Thanks,
Rodney
Old 08-23-2020, 03:23 PM
Rodney ,
The problem he has is the relocated pickups are turbo-spec , so using standard rear arms pushes your rear wheels back ( a good thing) but you need to “massage” the rear quarters to get the wheel back centered .
Turbo arms are Pretty similar to swb Arms dimensions wise , but it’s easier to use standard pickup points and standard lwb narrowbody parts .
He could even cut of what he has and fit narrowbody boxes , or make his own like tom did .
He really needs to come see my car , as Im only 30 minutes away and have Both turbo and Carrera rear arms , and both sets of mounting points to compare .
It will become clear in seconds when it’s all in front of you in person ....
Evan ,
His boxes and torsion beam are braced horizontally to tunnel and vertically/angled to the cage , and angled horizontally to the sills/rockers Inside the car .
Pretty much all you need to do has been covered .
His spring plates are FAR from stock ....
Old 08-23-2020, 04:42 PM
rokemester's Avatar
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 08-23-2020, 06:55 PM
Hi Michael,
You need to talk to ian c2 he obviously knows what he is talking about! And he is just down the road.
Good luck!
Old 08-23-2020, 08:20 PM
I’m not sure that’s a compliment ...
I pride myself on appearing absolutely clueLess about everything !!!
In truth ,
I have the parts to show him what he has got and what is needed , and a car that is set up for both scenarios , and the ability to lend him parts to do mock-up and measuring .
I a;so know a bit about music and crappy british hifi
Old 08-23-2020, 08:52 PM
Kraftwerk's Avatar
If any area of the 911 could use some forward-thinking-reverse-engineering it's that particular point --a little more room is needed there at that point, in order to get normal-sized sockets wrenches to easily fit w/o specialized tools or dropping the transmission ...etc.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 08-24-2020, 08:44 AM
You mean the bolts for the arms ?
Use wevo split-bolts .
Old 08-24-2020, 08:46 AM
Kraftwerk's Avatar
Nice: WEVO E-Z Pin ..Wish the factory had used them!
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 08-24-2020, 10:55 AM
rokemester's Avatar
+1 on this comment! I had to drop my motor on my 87 because there was so much interference from various lines coming to the rear of the car, particularly on left side of the car. Wevo solution is awesome but spendy.
Northeast Ohio
1966 VW Beetle, 6V
Old 08-24-2020, 03:46 PM
