'79 911SC Targa
FL911SC's Avatar
What Goes Here?
Greetings all,
I am getting ready to start the overdue project of replacing my SC trombone type cooler with a Carrera type including a fan.
At the top of the oil cooler, on the opposite side where the oil lines are, there are two threaded holes (see picture). The larger one is for the thermostat switch, what is the smaller hole for?
While researching it looks like it is just a bolt, is so why is it there? When I look into the hole, it does look like a very small hole at the bottom, so do I need rubber washer are anything special to seal it up?
As always, thank you for all the help!!
Keith
Old 06-17-2021, 12:14 PM
RETIRED
Joe Bob's Avatar
Thermostat?
2012 ML350 3.0 Turbo Diesel
Old 06-17-2021, 12:20 PM
'79 911SC Targa
FL911SC's Avatar
Joe B, I think the other, larger, hole is for the thermostat. But I have been wrong before. :0)
Old 06-17-2021, 12:25 PM
HarryD's Avatar
Not sure but it could be a vent hole. The PET catalogs do not show this hole.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-17-2021, 12:45 PM
proporsche's Avatar
there goes nada look here...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-17-2021, 01:32 PM
RETIRED
Joe Bob's Avatar
I'm still going with a thermostat for the cooler fan. I'm old and it's been awhile......
Old 06-17-2021, 01:35 PM
The smaller, threaded hole that doesn't go through is for the ground lug, if you are using the single connector type thermostat switch. If you convert to the BMW two connector switch like many do to get the fan to come on at lower temp, it's not used.
Old 06-17-2021, 01:39 PM
RETIRED
Joe Bob's Avatar
Contact BAT Inc. they will give you the schizzle....
Old 06-17-2021, 01:41 PM
proporsche's Avatar
the thermo switch goes on left..
Ivan
Old 06-17-2021, 02:11 PM
Yes. Switch on left. Ground on right. At least for an 1988 factory setup.
Old 06-17-2021, 02:19 PM
Possibly a drain?
Old 06-18-2021, 07:32 AM
stevie 77 930's Avatar
+1 this threaded hold is for a ground wire. In theory, the oil cooler is supported by the rubber bushings, there by lacking ground continuity. The larger hole on the left on the OP picture is for the thermostat.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 06-18-2021, 08:20 AM
1983 911SC
2018 GTS
2023 Audi A4
Old 06-18-2021, 08:26 AM
'79 911SC Targa
FL911SC's Avatar
Thank you to all, I always appreciate this forum. I was looking at more post and pictures over the weekend, (trying to make me feel better about installing this myself) and will have to agree with the ground-wire answer. There are some pics out there which show a brown wire there. As well, stevie 77 comment about the assembly being insolated by the rubber bushing makes since that the radiator would need to be grounded. Since I am planning to install a fan (FL heat and traffic is horrible) then I be sure to include a ground wire to the radiator.
Thank you again everyone!!!!
Has anyone seen my 10mm??
Old 06-28-2021, 06:15 AM
Tags
oil cooler
