Must go faster...
Huge backfire, no start
She’s a 1978 SC. Recently had the top end redone. All new gaskets, seals, and hoses. Took her out for a drive. Ran great for an hour and half. Didn’t really push her that hard at all. Came into a corner, slowed, downshifted and all of a sudden lost all power. She backfired loudly and died. Now she wont start. Turns over just fine, but nothing.
Anyone have any thoughts on where to start looking? Thanks in advance. |
Take the air filter cover off and see if the pop-off valve popped out. If there is one. Then check if the top and bottom of the plastic intake airbox separated at the seam. If you see any screws out or 1/2 way out, that's an indication.
Massive air leak........
Your airbox has been compromised. You need to do a smoke test to locate and identify the source of your unmetered air.
Tony |
RETIRED
If you had a professional wrench do your top end and he/she didn't install a or off valve or inspect your air box, feel free to go out and slap the crap out of them...
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Still here
Split airboxes can be a fire hazard if you keep trying to start the engine with the cold start injector spraying fuel.
Targa_PB_78_SC
If it's not your airbox, check the plug-in to your CDI box. I had a similar experience (loud back fire, quit running, no start) until I got the loose plug in tight.
BareRearedRookie |
New-ish 911SC Targa Owner
That's how my car grew internal throttle bodies.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
