Replacement Fuel Tank - '83 911
Hi guys, it looks like the previous owner of my car may have done a bit of off-roading, and unfortunately there's a large gouge near the drain plug on my tank that appears a bit damp, and from time to time I'll get a whiff of fuel in the passenger compartment.
After reading the forum and looking at replacements, it looks like Dansk and TMP/Tasker both make aftermarket tanks. I understand the Dansk isn't capable of accepting the factory tank strainer, and using it usually necessitates modifications to allow the use of a pre-pump filter.
It also looks like the Tasker/TMP tank may have some quality issues insofar as welds and galvanizing are concerned, but that it does allow for the use of the factory strainer.
With all that being said, it looks like a new factory Porsche tank is about twice the cost of an aftermarket tank. While it's not necessarily a small sum, it sounds like it may be worth spending the extra few hundred to use the Porsche tank, but I've also read several threads related to other Porsche parts where the modern equivalent that has superseded past parts isn't necessarily the same as what was installed at the factory.
With three small children and limited time to do this job, I'm leaning heavily towards the Porsche tank. Has anyone used the factory Porsche replacement tank? Any thoughts/recommendations/regrets?
Thanks in advance!
Old 07-15-2018, 01:43 PM
Functionista
manbridge 74's Avatar
We’ve installed a few. Direct bolt up to the SC but requires some plumbing adaptions on earlier cars. They appear galvanized, have correct gray coating, come with the swirl pot and pre-filter already installed.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 07-15-2018, 02:16 PM
I have a Dansk. You don't really need a pre-filter
Old 07-15-2018, 02:21 PM
Functionista
While true I believe the fuel pump will last longer if there is at least an inline filter of suitable size.
Jeff
74 911, #3
Old 07-15-2018, 02:25 PM
Jeff, thanks so much! There appears to be some significant price discrepancies in the factory part depending on the final suffix. For instance the -02 is about $1000 less than the -05, yet the PET diagrams show them as all fitting the SC. Any idea what the difference may be? The Porsche dealers with online catalogs all show them as genuine Porsche and available for order.
Old 07-15-2018, 02:38 PM
Functionista
The reason is because the -02 is NLA and the supercession is the -05. Least it was when last I looked.
Jeff
74 911, #3
Old 07-15-2018, 03:45 PM
