The annual engine casting marks OR cracks post
So here it is.. I looked at a few older posts. Most of this looks like casting but I wanted second opinions,
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
(man/dude)
Casting. I was alarmed at the SC block I cleaned up.
My latest one, a 3.2, looks quite a bit better I guess they re-did the moulds.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
![]() How's this for scary?
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
Holy cow!
To be clear - above pic is still casting marks.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Titanium User
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Thankfully yes!
I nearly went into cardiac arrest. Check your 915's, just for fun.....
'73 911 T Targa
this is a casting Mark?
This one look just as bad as that one in person. I looked at a lot of cases that had the same casting marks.. but nonetheless they freak me out and look like cracks.
Titanium User
I bought an 84 Targa last year, and have been enjoying it. When winter hit, I put her on the lift and cleaned up the floor pan and washed the trans/engine case/etc that had probably 10 years of grime. My 84 trans has that exact casting mark, and I thought it was a crack until I saw this post. I'll post a pic of my trans, I thought that picture above was my trans because the casting marks are identical!
