Micro switch adjustment on 1972 911T MFI
Hi folks.
Another question about the 72.
When the throttle is at idle position, the adjustable screw that activates the micro switch is just touching the switch. If I reach in with my finger I can push down on the switch and it clicks.
I have attached a photo that was taken with car not running and the engine cold.
Should the switch be pushed done until it clicks when the throttle is in idle position?
Old 09-03-2020, 05:36 AM
Rescuer of old cars
Arne2's Avatar
Yes.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 09-03-2020, 11:16 AM
Yes, and as I recall, to test the switch and solenoid rev the engine up to 2400-2500 rpm
and depress the micro switch and the engine should shut off . The micro switch only cuts off the fuel when on deceleration over 2300 rpm. it allows enough fuel for the engine to maintain an idle
Hope this helps
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 09-03-2020, 02:20 PM
setting
Close the throttle.Back off the adjustment.Turn the screw.When you hear it click turn 1.5 turns and do not touch it again.That is the factory setting.If your rpm transducer works life is good for you.Fred One more thing is the updated transducer is the one for a carb car from a 2.2 Zenith car to prevent stalling.Ciao from NC.
Old 09-03-2020, 02:37 PM
Fred , are my thoughts correct?
Ian
Old 09-03-2020, 02:39 PM
Response
Yes,your thoughts are correct but when the microswitch works and the transducer is in harmony as long as the microswitch is held down the motor will hunt up and down until you release the pressure on the microswitch.I hope this helps.
Old 09-03-2020, 02:50 PM
Thanks for the valuable answers.
I currently have the rpm transducer removed from the car because of a couple of detached diodes.
Larry
Old 09-03-2020, 06:26 PM
That means that the micro switch is inert . No need to adjust it .
ian
Old 09-03-2020, 07:38 PM
47silver's Avatar
There are a few threads in repairing the speed sensor. They transistor legs rust and snap check them also
Old 09-04-2020, 08:03 AM
