Installing bushings at bell crank
Bushings at the accelerator plate and mechanism in the rear of the car were shot, so I pulled the plate and cleaned out the errant bushings. Can't figure out how to press the new bushings into place. Will i need a press, or can this be done with hand tools? thanx steve ('74 Carrera)
Steve Meltzer
'69 911E/bastard
Old 08-23-2020, 10:21 AM
Hand soap and a c-clamp. If they don't fit shave them down a bit with sand paper.
Old 08-23-2020, 11:51 AM
i used some white lithium grease, but that didn't do it. i'm also thinkin' a second set of hands, i'm sure my wife won't mind (afterall, the car is in her name!). Thanx for your advice. steve
Steve Meltzer
'69 911E/bastard
Old 08-23-2020, 12:26 PM
Looks like you have the 914 part used on the bell swivel on the trans
You want the 901 part number, it just slides in, no problem
Bruce
Old 08-23-2020, 04:33 PM
Bruce, you're correct!! I have the 914 number, but can't find the correct 901 part number on Pelican. Can you let me know what the correct number is? Greatly appreciated. Great not to fight with this. thanx again. steve
Steve Meltzer
'69 911E/bastard
Old 08-23-2020, 05:10 PM
Vintage Owner
Jack Stands's Avatar
Try 901 423 253 00, that should be the right number.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 08-23-2020, 05:47 PM
That’s it ^^^^^
Your trans swivel probably needs new too. 914 part works there
Bruce
Old 08-23-2020, 06:56 PM
thank you both!! what's that part number? thanx again for holding my hand while i figure this out!! steve
Steve Meltzer
'69 911E/bastard
Old 08-23-2020, 07:18 PM
Thanx again for the info. With the correct parts it was a 5-second job!
WOW! steve
Steve Meltzer
'69 911E/bastard
Old 09-01-2020, 06:24 PM
