 Alternator Light My alternator light is staying on from idle to about 2500 RPM intermittently. Time to replace or anything to check first? It’s an SC engine. I’m somewhat handy, is this difficult to do? |
 Well, it is not the alternator light that is at fault; it is reporting a problem with the charging system. The alternator and/or regulator may be faulty. Other possibilities include wiring and battery. |
 Yes I meant replace the alternator. Is there a test to see if it’s the alternator or regulator or are they one unit? |
 It can be either on a car that is 40+ years old. Please state the year of the car, and is the engine original, or a swap. More details on the vehicle will help in an accurate diagnosis. |
 Can be a loose belt |
 Miss Cleo may know, but the rest of us likely don't.. :) |
 As Mahler9th stated, it could be a loose belt, so start with that. If good, then check the VR if external. Jason |
 My car is a 1977 Euro 911. It has a 10 year old rebuilt 3.0 SC in it. |
 What year SC engine? Do you have an internal or external voltage regulator? (look beside the CDI for an external one) |
 What kind of voltage are you getting at the battery? OFF, idle and revved. |
 Internal VR |
 Loose belt, regulator or worn brushes are the most common culprits. If it is only on at startup until your first higher rev, that is normal. With worn brushes the light ends to flicker a lot. With a loose belt, the light tends to glow dull under electrical load. |
 Alternator light came on and stayed on my '76, replaced regulator before taking alt off, fixed it. |
 So my light on is intermittent, goes off above 2500 RPM, anyone vote to replace the brushes or is that a PITA to do as well? Replacing the alternator is about $800. |
 An alternative to buying a new one would be to have yours re-built. Get a recommendation for a local shop that does that work, you could save a lot of $. Jason |
 since the VR is triggered by the alt lamp, is the correct lamp in the gauge? |
 Get one of those cigarette lighter volt meters.  I got one off of eBay.  It helped to know the voltage with my charging problem. |
| All times are GMT -8. The time now is 06:42 PM. |
