Why would this hose be blocked?
While cleaning the engine bay & adjusting the valves this weekend, I found this jammed in one of the oil breather hoses. Why? What could be a reason for plugging it? (I just picked this car up recently) TIA. -John
'73 RS Clone (flared, lowered, backdated, swapped)
'72 124 Spider (newest project; shaved & lowered cruiser)
'97 328ic (wife's toy)
'05 3500HD D/A (tow vehicle)
Old 05-17-2004, 05:17 PM
Randy Webb's Avatar
PO probably found gunk on air cleaner or wherever this hose goes in yur car. Or hose ruptured... Prob. a lazy PO.
Old 05-17-2004, 05:23 PM
This hose goes to the bottom of the MFI air cleaner. The hose appeared to be in pretty good shape.
Old 05-17-2004, 05:31 PM
SC-targa's Avatar
Doesn't that hose go to the charcoal canister for the evaporative emissions system?
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 05-18-2004, 11:22 AM
That is the crankcase/oil tank vent outlet. If it's plugged, crankcase pressure cannot be vented to the intake tract via the air filter housing. In some cases, this could cause external oil leaks. Put it in your tool box drawer labeled "misc".
The PO probably plugged the line to prevent oil vapor from entering the air filter housing.
Sherwood
Old 05-18-2004, 11:28 AM
Do I ever have oil leaks. There is oil exiting from almost every oriface on this car.
Here I am replacing every gasket I can to stop the leaks, when all I had to do was remove this plug that the PO stuck in there.
j/k
Old 05-18-2004, 11:34 AM
I guess I have a way of understating things.
I hope this cures the symptoms.
Sherwood
Old 05-18-2004, 11:38 AM
