AndreasK's Avatar
Had to do a before and after shoot
1977 911s
Old 09-16-2020, 05:16 AM
AndreasK, nice work.
I've been looking to do similar with my 1977.
Looks like you also did a rear bumperette delete.
What did you fill the holes with?
Are use using the original Euro rear rubber corner strips?
European vs US bumpers
Rear rubber strips be they Euro-spec or US, same length?
Rear wheel flares, SC, ST or something else?
Originally Posted by AndreasK View Post
Ive also seen it done with US bomper shocks. Then you drill a hole, to lett the fluids out. Compress the shocks to your desired length, an seccure with a skrew.
Thanks for the info, will do a search on those threads. I've only seen the custom light weight crush tube threads.
1998 Chevy S-10 4x4 Pick-Up Truck, Razzle Dazzle Camo
Old 09-16-2020, 05:49 AM
AndreasK's Avatar
@kach22i
Holes in bumper was plugged with a JB weld type "metal".
The car is a US model, so the corner rubber is the US ones. However I think they are the same as the Euro.
The flares I actually think are "RS". Previous owner installed them. But they are pretty much the same as SC. Mine are fiberglass 😥 Next project will be to change them to steel😀🤓
Old 09-16-2020, 11:20 AM
well done, looks very nice
Old 09-16-2020, 12:06 PM
Thank you for the information.
When I took my bumperettes off the steel bolts in them had expanded/rust and made the hole in the aluminum bumper irregular and enlarged.
I cleaned and then filled the hole with an epoxy faux metal in a small cylindrical container, similar to the below.
https://www.jbweld.com/product/steelstik-epoxy-putty-stick
I think there might be better ways to do it, so thought I would ask.
I do like your wheel flares, not standard SC and would keep them.
Old 09-17-2020, 06:40 AM
AndreasK's Avatar
Welding would be better😀👍
Old 09-18-2020, 06:43 AM
JED
ARCSinAK's Avatar
How about your source for the rear plate lights? I just welded the bumberette holes on a spare SC bumper. I have a set of LED plate bolts but your clean.
Old 09-19-2020, 12:49 AM
AndreasK's Avatar
Not shure what they are. Came together with some spare parts, when I bought the car
Old 09-19-2020, 11:53 PM
Iím not typically a fan of the stying changes made on 964s but man yours look really good. Especially with those wheel.
I too prefer G bumpers on a G body. Some of my favorite Porsches have accordions
Good job
Tony
Old 09-20-2020, 03:10 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
