-   -   Audette Collection signal bulb kit Question (http://forums.pelicanparts.com/porsche-911-technical-forum/1072432-audette-collection-signal-bulb-kit-question.html)
70sCars 09-07-2020 09:32 AM
I recently purchased the Audette Collection AC high performance Signal bulb kit and took the car out yesterday which turned into an evening trip home. When I turn on the lights the interior directional light indicators both lit up on the gauge. And when I used the turn signal lever - no turn signal lights came on up front or in the rear. I turn turn off the lights and all the turn signals work. Do I need a new signal/high beam lever? What's going on here?
Audette Collection: The Definitive Resource on Vintage Porsche 911 Lighting | Concours Restoration of Porsche SWB 911 Headlamps, BOSCH H1's & H4's + LED Headlights
Arne2 09-07-2020 09:48 AM
Check the fit of the bulbs in the sockets. Sounds like they aren't grounded properly.
AG81 09-07-2020 10:29 AM
Could be a ground, a bad bulb or a bad flasher.
spoke 09-08-2020 03:55 AM
I agree.
Electrically the running lights and turnsignals are independent. The only electrical connection they share is the ground connection in the 1157-type running/turnsignal bulb bases.
Check the fit of the bulbs and while lights are on and turnsignals not working, try removing one of the new bulbs and replace with the existing 1157-type incandescent bulbs.
BTW, are the new bulbs LED types?
famoroso 09-09-2020 08:07 PM
Originally Posted by spoke (Post 11018090)
{snip}
Nope.
70sCars 09-10-2020 06:23 PM
No. The Honda bulbs supplied by Audette collection.
