-   -   Msd fusing in a 75 (http://forums.pelicanparts.com/porsche-911-technical-forum/1072476-msd-fusing-75-a.html)
47silver 09-07-2020 05:20 PM
Msd fusing in a 75
Should i put the fuse at the source if +12 which would be the starter or in the engine bay
1975 911s.
timmy2 09-07-2020 10:11 PM
Yes, fuse the constant 12vdc. Likely more convenient by the MSD unit.
47silver 09-08-2020 05:55 AM
fuse
thanks
i was thinking more along the lines of the wire being cut,, but if i put a protective sheath on it then the fuse close to the MSD would protect the car from a faulty MSD.
juanbenae 09-08-2020 08:03 AM
i fused mine from the starter 12V right where the wire enters the motor compartment near the passenger side shock tower.
47silver 09-10-2020 12:33 PM
That is where i will put it
