Help - Sourcing OE 2 Pin electrical connectors
Hello,
I’m trying to find original electrical connectors like the ones pictured (2 pin). I have searched without success. Are they available new? Or does any one have a stash of them they’d sell?
Thanks,
Kelly
Old 09-14-2020, 06:49 AM
7783911's Avatar
Try British wiring
Old 09-14-2020, 06:53 AM
Hi, The female spade connectors in side the plastic housing are removable. There is a locking tab holding it in. They can be released by using a heavy pin to release the tab. You can purchase the female spade connectors at belmetric.com measure the side of connectors to get the right size. Also you need a open barrel crimping tool you can find then on Amazon.
Hope this helps.
Old 09-14-2020, 07:29 AM
I bought this same connector a short time ago at Digi - key
https://www.digikey.com/
Part numbers
180907 - 5 - female receptacle
180908 - 5 - male receptacle
42100 - 1 - male pin
42460 - 1 - female pin
The metal pins need to be connected to your wire ends and then snapped into the plastic connectors.
Old 09-14-2020, 07:32 AM
Originally Posted by 7783911 View Post
Try British wiring
Great! Looks like I found it there. Thanks for your help!
http://www.britishwiring.com/Washer-Pump-Plug-p/c841.htm
Old 09-14-2020, 07:45 AM
The PETs for the 89 Carrera have a listing of electrical connectors starting at Illustration: 902-50.
815-971-989-A Connector housing 6,3
111-971-986 Flat plug with Clip 6,3 x 2,5
Old 09-14-2020, 07:57 AM
Part numbers
I have ordered from digikey before. Great source. I struggle to find the part I need but you nailed it! I’m gonna try to cancel my order with British electric.
Old 09-14-2020, 08:32 AM
Awesome. I always forget to look at the PETs. Thank you.
Old 09-14-2020, 01:59 PM
