Shop Labor Estimates
I’m looking for some reasonable shop labor hour estimates by an experienced Porsche shop for a 79 911SC for the following:
- Remove engine - Remove & replace clutch, pressure plate, disc, pilot bearing and flywheel - Remove old chain tensioners and replace with new hydraulic tensioners - Remove and replace oil return tubes - Re install engine - With engine out, remove and upgrade with new AC compressor and AC lines to front - With engine in, remove and upgrade with new AC compressor and AC lines to front Any additional info and /of advice welcome. |
Post your location.
shh-the robot is sleeping
Whatever $$ you come up with, add 30% for suspension odds and ends, axles, exhaust troubles, starter or alternator or both, fuel lines etc... Assuming you are certain the headstuds are all good or the engine was recently rebuilt.
'88 911 Coupe, 69k miles |
What city?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Been here a while
Da Vinci nailed it. There’s $5k worth of add ons and possibly another $5k worth of ‘oh $hit’ stuff
That list, to me looks like $6k in labor. AC stuff isn’t difficult but it is a lot of time. And you really should do a valve adjustment and I’m sure there will be plenty of seals and gaskets that’s should be tended to.
looking for 1972 911t motor XR584, S/N 6121622 |
Been here a while
OP stated he wanted labor only. I'd agree with your $10K estimate for parts and labor
Our aircraft mechanic doesn't charge that hourly wage.....
I spent 2k on labor with my independent P-car mechanic here in S Florida. I provided the suspension parts. All back to stock, nothing more.
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
