doc911's Avatar
Carrera 3.2 door
Hello Forum,
How to limit doors wide opening in my 1987 Carrera?
It's troubling me in narrow parking areas. I have to squeeze myself in to avoid pumping the car parking next to me.
Any after market parts to solve this problem?
Thank you.
Old 09-07-2020, 06:35 AM
Don't park in tight quarters? They'll door ding you. Nobody cares.
206 637 4071
Old 09-07-2020, 07:01 AM
Take the stop off and drill a new hole on the inside end. Replace pin.
Old 09-07-2020, 07:58 AM
doc911's Avatar
Dear salayc,
More explanation please?
Thanks.
Old 09-07-2020, 09:52 PM
Send a message via AIM to fintstone
Sounds like your door stop needs replacing:
https://www.pelicanparts.com/More_Info/96453705700OEM.htm?pn=964-537-057-00-OEM&bt=Y&fs=0&SVSVSI=827
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-07-2020, 10:23 PM
Originally Posted by doc911 View Post
Dear salayc,
Thanks.
Looks like it would be easiest if you use the aftermarket replacement, but here is the pin on the OEM and aftermarket. Just choose a position a little further towards the jamb end and drill a new hole.
Old 09-08-2020, 07:10 AM
doc911's Avatar
Thank you very much, salayc.
Old 09-11-2020, 01:09 PM
