Speedy Gonzalez
TonyGO's Avatar
Squeakie Suspension
1979 911SC. Front Ball joints have been replaced,also rear spring plate bushings replaced, suspension squeaks at low speeds,anyone know how to repair this, or what could cause this?Thank You
Old 09-08-2020, 03:54 PM
Need to know if the squeak is coming from the front or rear....
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-08-2020, 04:18 PM
sway bar bushings?
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 09-08-2020, 06:56 PM
El Duderino
tirwin's Avatar
I had a squeak that was driving me crazy. Best advice was to spray lubricant on suspension components one by one until I found it. Turned out to be rear trailing arm bushings in my case.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 09-08-2020, 07:47 PM
PRO Motorsports
Tyson Schmidt's Avatar
Most common is the torsion bars rubbing the inside of the front control arms.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 09-08-2020, 07:59 PM
Lash
We have speed bumps in our neighborhood and was able to hear my front end squeak when driving over them.
As Tyson S. mentioned, I had to replace worn out rubber bushings on the front control arms.
Lash
1963 356 T-6 Normal Coupe
1972 911 T Coupe ..... Sold
1972 911 S Targa ...... Sold
1980 911 SC Coupe Weissach
Old 09-08-2020, 08:18 PM
Is this a good idea? If so what kind of spray lube should one use?
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 09-09-2020, 05:17 PM
Use silicone if you do this. Other petroleum based products will damage the natural rubber in the stock bushings.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 09-10-2020, 12:04 AM
El Duderino
tirwin's Avatar
^^^ agreed
Old 09-10-2020, 07:33 AM
Location: behind the redwood curtain, (humboldt county) california
A quick squirt may help you diagnose the source
If a quick shot of lube stops the leak, this might help you to pinpoint the source, but it may not be a good fix. Most bushings are not designed to slide in their mounts or the part in them, so it might be time toreplace some rubber. I think antiroll bar bushings might be an exception. A quick shot will tell you where, but you might do better to pull the bar mount down, clean and lube the bar and inner surface of the bar mount with some silicone grease - this should last a lot longer.
If the Tbar is metal to metal, or any other part of the 911 suspension is metal to metal, it is time for replacement.
chris
Old 09-11-2020, 08:03 AM
El Duderino
tirwin's Avatar
Right... I wasn’t suggesting that as a fix. Just a way to clearly identify the source.
Old 09-11-2020, 09:15 AM
