PMO Carb Stuff
The idle air jets have a relatively large orifice/hole (~0.135mm, about the diameter of a needle) as compared to the idle mixture jets (diameter of a couple of hairs...). As such, idle mixture jets are the most likely culprit to investigate for a stoppage / clog causing a new hesitation / coughing / low RPM sputtering condition. Gordo |
Quick Video - Colortune
Quick shot at an instruction video for the Colortune.
Comment on taping a penny to the mirror & tossing in the trash is attributed to Mr. Paul Abbott of Performance Oriented who is the carb guru... <iframe width="971" height="546" src="https://www.youtube.com/embed/j6pam6Ql_JE" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
Gordo - thanks for sharing the video. I wasn't familiar with that tool.
GREAT. But Gordo, what do you adjust to? Is it specified in the CT instructions? Do you want an even blue flame for every cylinder? Which screw do you use to adjust? air, fuel or both. Thanks
pmo carbs
I have the same issue ,pmo carbs on 3 litre s/c je 9.5 pistons 964 cam, msd ignition , runs very strong ,idle jets plug up continually opened up both carbs @ found some white corrosion like stuff in the bottom of float bowls ,cleaned it out ,all was fine .A month later ,it is happening again ,what is going on ? canadian gas ,chevron 94 octane
? Filter
Either way, what are you using to filter your fuel? Seems it may not be sufficient. I run a Racor 110a and don't have issues idle circuit / jet blockage debris all that often. Good luck. |
| All times are GMT -8. The time now is 04:38 AM. |
