Order yours today!!
The must have for your 911!
EGADS!!!! ]EGADS!![/URL] Fits year: 1992-1991 A sticking Porsche thermostat will cause your Porsche 911 to either heat up or not heat up enough causing your car's engine to work harder than it needs to. If your Porsche 911 thermostat sticks open then the water temperature will not get warm enough because water will pass through the system without having a chance to hold and become hot. If your Porsche 911 thermostat sticks closed then the water temperature will become to warm and overheat your Porsche 911 engine. Search through our online catalog for the Porsche thermostat that is right for you and make sure your engine is at the right temperature.
'99 996~LSD~VE Wheels~H&R Cup Kit~Aero~Recaro~X51~M&K~GT3 Roll Bar '77 911 ~ very modern running gear ~ Gruppe B...the Midwest motorsports playground |
The only hot water in my 911 is in my coffee cup.
'83 SC Coupe- Blk/Blk '03 Daughter- 10fingers/10toes |
