jtkkz's Avatar
Momo Prototipo flat
What Momo hub will work for a flat prototipo to work with 74 911?
Problem with flat prototipo is that the turn signals are too close to steering wheel
Old 09-14-2020, 05:28 PM
@_more_momo
Outlaw_singer's Avatar
if the wheel is too close, you can try the L231 hub which is about 17mm longer than the regular, C231 hub.
Or, in case you already have a C version, you can buy a momo spacer which measures 9mm. They are also available as an eccentric version which brings the wheel up a little.
https://www.instagram.com/_more_momo --> For those interested in my steering wheel collection, feel free to have a look
Old 09-15-2020, 12:42 AM
Flojo's Avatar
or get an excenter ring (instead of blunt spacer).
it will also lift the wheel up some
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 09-15-2020, 04:59 AM
