Steering Wheel ID
Folks, need your help here. I pulled this wheel from my '74 911 with the intention of going Prototipo so this will likely be going up for sale shortly. Based on my research on this site I believe this is a concentric Sport version but given the 4" rim diameter it may be a "fatty".
Any input on specs would be great as well as thoughts on current market value. Thanks in advance. ![]() ![]()
http://forums.pelicanparts.com/porsche-911-technical-forum/1055834-project-olly.html |
Definitely a hub-centric "FATTY"!!! I would get it the proper stitching and put it back on!
Looks like it.
Can you shoot a pic without the horn pad? |
It is indeed a fatty. Value is all over the place. I have seen excellent original condition ones go for as much as $1200 but they are cherry original. I have see restored ones go as high as $850. Restoration all in including restoring the wheel as you have some corrosion or something could reach $600 easy. Do the math.
Very helpful, thanks for the input much appreciated.
Is the rim diameter what makes it a fatty? or are there other tell signs?
"It's only temporary unless it works" 1974 911s turbo-look stock 2.7 engine "Dirty Martini" 1953 replica 550 spyder built from the ground up, EJ25 engine Speeduino ECU |
All the fat rimmed wheels have that thick steel plate center, but not all thick plated center wheels have a fat rim.
The later stamped sheetmetal centered wheels have only thin rims. |
Don't mean to hijack the thread but would this one be considered a fatty? Came off my 74 diameter of the ring is 3 5/8 on the finger indentations, it has no leather cover
What’s the 3 digit date stamp? I think every single late 73-74 3-spoke wheel is a fatty if I’m not mistaken. They exist after as well but as special order I believe
Thanks for the reply, heres a picture I just took, seems like it should have a number stamped over the 33? Apart from the 33 I can only see a 914 over the spline, my 911 is far from stock, the car was fully converted to a 930 look I believe using a real 930 as donor so maybe the wheel came from that one also?
Rim circumference, not diameter. And the valuable wheels seem to be the symetrical ones.
Thank you for the info George I appreciate it
Oops that’s what I meant on both accounts, was bedtime lol, thank you
