Oil leak under #1 cylinder
I was under my 87 930 and saw oil on the cooling tin at cylinder #1. Any thoughts as to likely culprits?
Thanks! ![]() Sent from my iPhone using Tapatalk
1987 Marine Blue 930 1982 911SC White Plains, NY |
for this you have to remove your valve cover on that side.and check your rocker shaft pins if they are tight or in correct place ...
next ..it looks like it has been there for a while so check the cyl.heads nuts if they are tight.. Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks Pro. Looks like my next oil change will be a little more involved....
