-   -   stuck CSI sensor plate and lever (http://forums.pelicanparts.com/porsche-911-technical-forum/1072984-stuck-csi-sensor-plate-lever.html)
mikedsilva 02-09-2025 01:31 AM
Originally Posted by Schulisco (Post 12407537)
The Haynes contains an exploded view of it... there you can see all its parts...
yep, straight away i saw my error, I put the spring in the wrong side!
all fixed now, thanks.
E Sully 02-09-2025 07:03 AM
Originally Posted by mikedsilva (Post 12407515)
got it apart ok.
cleaned it all and seems fine.
I reassembled and realise only 1 side has the spring. My operating lever rotated smoothly ( i oiled roller and pivot shaft with engine oil) but the lever can move side to side which isn't right... not sure i put the spring in the right side or maybe it's caught up.
Will pull apart and check my work...
I used a bamboo chopstick to push out the pivot pin.
Yes one spring goes on the side of the housing that extends out. Clean off the oil and use silicone (dialectric) grease as specified in the repair manual.
It can shift side to side till the counter weight screw is tightened.
I show a bit of the assembly in post 43 of this thread we had last year.
http://forums.pelicanparts.com/porsche-911-technical-forum/1108835-cis-sensor-plate-height-3.html
