fmcolorado
Which battery maintainer to purchase
I have a 73.5 911 with two lead-zinc wet-cell batteries connected in parallel. I would like to purchase a trickle-charge maintainer so the batteries don't discharge when the vehicle sits idle for 4-5 months over the winter. The cigarette lighter is OFF when the vehicle is not running. Porsche sells a "Pro-Battery Maintainer" that costs 2.5 times the CTEK MSX 5.0 Is there something different in the Porsche-branded unit that would justify it's higher cost (other than the Porsche name)? I don't want to spend more than I need to. Thanks, Fred
Old 09-17-2020, 10:05 AM
You should also consider the Battery Tender offerings....have used the successfully for years with my Porsches. I also have several CTEK units from PORSCHE in use, but if you're looking for the best bang for the buck, try the Battery Tender units.
Old 09-17-2020, 10:21 AM
fmcolorado
Would it be better to buy two battery maintainers, disconnect the batteries from the car, and charge/maintain them independently over the cold winter months? Ofcourse, that means 2 times the cost. Fred
Old 09-17-2020, 10:24 AM
If you buy one, try to get one that will charge not only lead acid batteries, but the AGM style batteries. May need it to charge up an AGM battery one of these days & you'll be glad you have a compatible charger.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-17-2020, 10:34 AM
fmcolorado
What do you people think of this unit for maintaining the two batteries independly:
Battery Tender 2-Bank Charger: 12V, 1.25 Amp Battery Charger with 2 Charging Banks - Smart Battery Charger and Maintainer
Old 09-17-2020, 10:43 AM
fmcolorado
Costs $100. Fred
kbken62's Avatar
Few months back, Costco had Battery Tenders for $39. Picked up two. Work great. I had a cheap Harbor Freight tender for an old battery and it seems to work fine as well.
Old 09-17-2020, 10:59 AM
'73 911 T Targa
I have a GUEST two bank battery charger that maintains two batteries that are not connected to one another. Works like a champ and doesn't appear to over-charge.
I also have a CTEK that is used in the car when the batteries are installed. That works great too.
Old 09-17-2020, 11:27 AM
gptom's Avatar
going on 5 years with 2 NOCO Genius G3500 Both work great
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 09-17-2020, 11:55 AM
