Clutch pedal went to the floor cable not broken
Driving the 82sc the other day I stepped on the clutch and BAM to the floor. Of course I ordered a new cable and it arrived yesterday. Disconnected the cable from the trans then went to the drivers side removed the pedal board and low and behold the cable was intact. The clevis had spread apart so far that it pulled off the clutch pedal bracket. Working on these cars for 30+ years I never saw that before!
I'm thinking it may have happened because I installed a heavy duty pressure plate.
Old 09-16-2020, 07:28 AM
nameisbauer's Avatar
Send a message via AIM to nameisbauer
Same. Maybe 82 was a bad year
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 09-16-2020, 08:12 AM
Interesting!
Old 09-16-2020, 10:31 AM
proporsche's Avatar
gome..i`d would say the same the press .plate..i assume well lubricated,right?
possibly metal fatigue on clevis can see anything on the break??
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-16-2020, 10:41 AM
Don't know how long since the cable was last replaced. The clevis didn't break it flared out like a Y to the point where the pin fell out of the hole on the clutch pedal arm.
Old 09-16-2020, 10:48 AM
I mean it only lasted 38 years, what the hell. I should get a warranty.
Jim
Old 09-16-2020, 11:02 AM
