'73 911 T Targa
Rotor resistance
Maybe a dumb question-
Should I be able to get a resistance reading across the contacts on the rotor? ![]() |
John W
That should be zero.
'73 911 T Targa
Thanks. That’s what I had thought. The one I’m testing reads open. I wonder how that could happen. Seems like there’s not a lot in there to go wrong!
There’s a resistor under all that black potted material- can’t remember the resistance off hand, but there will be some.
The resistor is a known “problem” area when running an MSD box as it will fry the resistor.
Rutager West 1977 911S Targa Chocolate Brown |
Under the radar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
Yes there is resistance. I have read 3K ohms. Mine reads around 5K ohms.
ROW '78 911 Targa
What scale were you using on the meter?
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI. Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. |
Under the radar
I have an old one that reads open as well. I believe the resistor just has burned out, as in open. It still works though.
'73 911 T Targa
'73 911 T Targa
Does the ignition coil get hot to the touch after a drive? In addition, a high voltage spark gap will tend to increase over time. Could eventually cause a misfire under load, equivalent to an excessively large spark plug gap. Sherwood |
In my 1973 911 2.76 MFI I removed the rev limiting distributor with resistor when I up graded the CDI from OEM Bosch,
I installed a Daytona-Sensores CD1 system and love it. I use the internal built in electronic rev limiter and set it to 6600 RPM. I used a VW non resistor rotor. The resistor rotor will burn out if you use a higher power CDI. I have had this system in my 911 for a dozen years and over 100,000 miles....and I love it. I also have a Pertronix point replacement system. I never have to worry about point adjustment or wear. The system just works.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Just measured my 70S spare rotor with my cheap meter, 5.18K Ohms.
'73 911 T Targa
Where can I get a rotor without the rev limiter?
I remember sourcing a VW rotor for my S distributor many years ago. Don't remember what MY VW.
They should be cheap enough to have in stock at your local FLAPS. Measure and compare dist. shaft and rotor radius just to be sure. |
No need to. If you have a limiting rotor like in the first photo, just remove the spring and take the plunger out. That will defeat the limiter.
www.classicretrofit.com |
'73 911 T Targa
I mostly don't want to spend the money on a rev-limiting rotor just to rip out the plunger for an experiment. That's kinda what started this post. I wanted to rip the plunger out of an old rotor, but it appears that rotor is toast.
Looks like this:
The 3.2 non-limited rotor fits an SC but the resistance is 1k ohms. SC is 5k ohms.
www.classicretrofit.com Last edited by Jonny H; 09-19-2020 at 01:04 AM.. |
Thread Tools | |
Rate This Thread | |
