ms3 evo cam sync
about to install my cam sync on my 930.
60-2 tooth flywheel reading about it it suggests at least a few teeth before the gap. if I set it 3 teeth before the gap that is about 5 degrees before TDC for #5 is that too close to the firing of #5 it says it really doesn't matter where it is set as long it is not set in the gap. |
| All times are GMT -8. The time now is 12:03 PM. |
