mordecaibrown's Avatar
Antenna Wiring
I took my 1977 911S into have some work done. When I got it back I see they cut the Antenna wire. I stripped the one end of the wire see pictures. But I can not find the other end to splice it to. The 2nd picture I taped the exposed end. If anyone can help with this that would be great!
Sam
https://www.flickr.com/photos/124038604@N05/50361466621/in/album-72157714639794462/
https://www.flickr.com/photos/124038604@N05/50361632672/in/album-72157714639794462/
Old 09-19-2020, 05:35 PM
Wanted to mention that when I turn the radio on the outside antenna still goes up. So no damage there! The radio in the car now is Blaupunkt form the 70's and needs repairs. I want replace it with somewhat vintage style new radio any suggestions.
Sam
Old 09-20-2020, 06:07 AM
'73 911 T Targa
The wire you describe has a threaded connection at the antenna and a plug-in connection at the radio. The one at the antenna is kind of up high; close to where it mounts to the fender. You should be able to trace it from the ends to the middle. Coaxial cables don't like to be spliced, so you'd be best served to replace it, or make the splice with a set of coax connectors.
Old 09-20-2020, 09:54 AM
