Door seal pushing door out
All original car, the back edge of the driver's door sits a few mm proud of the quarter panel and I can fairly easily push it flush.
It seems like the door seal is pushing the door out so I'm assuming it has been replaced at some point. Is it possible that the seal was incorrectly installed? Is there a way to make the door sit flush without messing with the hinges or striker plate?
1989 Carrera
Former flings...
2009 Carrera S (x2), 1986 Carrera, 1997 993, 1983 911SC, 1995 993, 1987 Carrera, 1985 Carrera
Old 09-17-2020, 11:01 PM
Don't fear the striker plate...an easy adjustment. You can always do a tape line on its vertical and horizontal plane to keep the original position, and then make an adjustment...you need to move the striker plate in a bit towards the interior of the car.
Old 09-18-2020, 05:37 AM
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
The door latch may only be engaging the first catch. This would allow you to push the door inward a bit, creating the feeling that the striker needs to be moved inward. Make sure you're engaging the first and second catch before deciding which way to adjust, if at all.
New seals often do this, and just need to be compressed a bit.
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD
1976 914 2.0 Lime Green Metallic - Completely stock
Old 09-18-2020, 08:14 AM
same thing on two of my 911's , the door seal is contacting the front lip of the door and adding resistance to the door close . I live with it
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 09-19-2020, 02:14 PM
