Looking for turbo part number or part
I can't seem to locate this part separately on any of the on-line parts schematics I have seen.
http://forums.pelicanparts.com/uploa...1600653762.jpg This is the drive pin for a 1993/1994 964 Turbo sump pump on a 3.6 liter engine. Just looking for the pin only, everything else looks good. Mine is showing wear and I would like to replace it while the engine is out. Thanks in advance for any and all help. |
Mic it. Maybe a drill bit shank is the same size.
It is hard. Takes a toll on the allen bolt heads. Maybe Brian @ rarelyl8 has one.
You may also want to consider a standard dowel pin for this.
McMaster-Carr has a good selection of Dowel Pins but other vendors should also have a good selection. |
| All times are GMT -8. The time now is 10:03 PM. |
