nadhome
79 911 SC - What are these Front brakes
Hi,
I've been told the front brakes are from a different model. Trying to identify what model they are from so I can get the right parts to service. I have a slight grind noise when warm and turning a corner. If I tap the brakes the noise goes away. Is worse on hot days. Have been told it may be a missing retaining pin or the pad might need to be replaced ? Thanks in advance for any assistance Cheers, ![]() ![]() ![]() ![]() ![]() |
Looking at the width of the caliper center spacer, 84-89 carrera.
nadhome
Bought the pads and discovered my issue with the noise on drivers front. One piston seized. Had different pads on either side. I'm guessing they threw in a pad worn enough to fit the gap where the piston was seized. ... just when you think it's a quick job ;-) |
