Designer King
Gas Analyzer in Toronto?
Since my engine has no O2 bung I would like to check my CO with an exhaust gas analyzer, like a Gunson.
Does anyone have one in the Toronto area I could borrow or rent? I could pick it up from you or use it in your garage or driveway. Thanks.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 08-18-2020 at 09:34 AM.. |
Analog Air Cooled
I know Autoselect has one as I checked mine when idjusting idle and AFM..
86 Targa 91 964 13 6 SPD Cayenne |
Designer King
Thanks Hotshot. I'll check them out.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
FYI. Gunson's are best used at idle speed. Response is too slow for on-road testing.
Designer King
Noted. Reading @ idle will be sufficient.
